big_chris1981
heater controls again.....
been to look at a C tonight and the heater direction contol only moves to the dash or face vent positions.......
have had a read through after a search.....
is this fixable, or is a new unit/passat unit the best option?
Hard to tell without taking the panel out and checking the back of it.
Sometimes it's just a matter of replacing the bowden cables.
Usually though, the plastic clips that hold the cables in place have shattered and a replacement panel is required.
hmmmm.
is it a case of just easing it out to have a look??
looks like ive got a list of things to do:
sunroof
heater controls
remove nokia car kit
get old imobiliser removed and something new refitted.....
fun fun fun!!!
Prise off the cover with all the markings on it.
There's four star headed screws behind it. Remove them and carefully wiggle the enter unit out of the dash. It's a little awkward and not helped by the fact the cables are attached to the back of the panel.
Once you can see the back of the panel, have a look at the cables and make sure none of them are floating around without the little metal clips holding them to the back of the panel.
There's a photo guide to fixing these somewhere. Just use the search and you'll find loads of similar posts.
Agree with Mike here - again there's a stack of info already out there if you use the search or look in the knowledge base.
Sorry to lock another ...
