TomD 0 Posted June 1, 2006 Hi! My bonnet won't open, when you pull the catch only the passenger side pops up, drivers side doesnt budge! Its worked fine until this afternoon! I can't see a way to get inside and pop the catch...is there a way to do it?? Cheers, Tom Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted June 1, 2006 http://www.the-corrado.net/wiki/index.p ... ening_tips Quote Share this post Link to post Share on other sites
Guest Posted June 1, 2006 this happened to mine a couple of weeks ago, I cleverly left a screw driver under the lip and the bonnet closed on it (it was dark!!!) mine opened eventually by having someone pulling the release, and me pushing down (to release the pressure on the catch), and then pulling it up. I found I could be fairly rough with it (I needed to be), you'd have to find out why its stuck though, as if its the catch itself then this won't work as you'll just be forcing it edit: or click the link above ;) Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted June 1, 2006 Its easy. Jackup the car. Slide under the front. have to hand a torch and a long screwdriver. When under the car use torch and find the bonett slam springs. These are were the bonett pins locate. Once found use screcriver reach up and prise the spring back. Bonett open.. :D Used it loads as my car had no cable when i bought it. Now back to normal ahh a cable and lever you can;'t beat em. Previous owner removed it as an anti theft thing :lol: Quote Share this post Link to post Share on other sites
TomD 0 Posted June 1, 2006 Cheers guys! I'll give those suggestoins a go! Not sure what I've done but I might have left something in there! :) Quote Share this post Link to post Share on other sites
TomD 0 Posted June 1, 2006 Right, you all get 10 brownie points! First Trick on the knowledge base with the seat belt on the handle worked a treat, was going to try that with soemone else pulling on it but I'm on my own at the minute! Thanks again! :) Quote Share this post Link to post Share on other sites
M15 VW 0 Posted June 1, 2006 Mine is like this. need to push on the bonnet a couple of times on the side that wont open to release it and maybe have someone on the handle inside Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted June 1, 2006 Sounds like you could do with adjusting the mech :wink: Quote Share this post Link to post Share on other sites
M15 VW 0 Posted June 2, 2006 Yeh i know, havent got round to it yet Quote Share this post Link to post Share on other sites
