mirroredone
Spacers for alloys....
Hola,
Can any one suggest what spacers i would need, for a set of 205-40-17 alloy wheels or weather i would need them,
I've had a look around the foum and i cant find anything on the subject,
cheers for your help.
all depends on the offset of the wheels!! It should be stamped on the back of the wheel somewhere.
im sure someone will be along soon to tell you what the ofset of the standard wheels are so you can work out what spacers you will need.
depends on the offset and width of the alloy rather than the tyre size, and also which model corrado you own. if its the valver in your pic, and your wheels are say et35 and 7.5" wide, a 5-6mm spacer would see them sitting nicely in the arches.
