heliosjim
How many bolts.............
Removing a front wing from my rado and wondered if there is more than one bolt under the wing holding it to the door hinge panel.
Ive got the one on the sill and one attaching to the inner wing, anymore hidden under that underseal?
Every other VAG car ive had has at least 3 bolts, need to check before i try ripping it off! :mad:
thate's always one hiding, you should be able to see where it's roughly at by gentle flexing the wing away and see where it's fixed.
I'm guessing you are on an air base?
Chris
If my Goldfish memory is holding up..
There was one attaching the wing to the sill.
One where I had to open the door out to gain access, near the top.
Removed the liner, and there's one right at the back about a third of the way up. Could be hiding amongst a ton of underseal, mine was.
