Jules
Noisy rear spoiler
My rear spoiler when going up and down is making an embarrassing groaning noise lol! I know that it must be needing greased or something cos it sounds like the rubber or whatever the material is is sticking.
Just wondered if anyone has had this problem and what they used as I woudnt like to put anything near it which might end up damaging the paintwork around that area.
hello, i had this an just used castrol bike chain spray on the vertical legs, any lube should be ok,just check back of can :)
The castrol might work fine, but i don´t know if the rubbers like it...
I have used PTFE spray (same as charger) on my previously Corrado.
The actual one is ok for now! :)
Ok thanks, this is the first thing on my 'niggly list' of things to be done but lately I have lost heart a bit with the car.....but this weekend is the start of things! Then I can start on the 'major list' !
There may be more questions to follow lol
Its always the little things which pee you off the most but, when it comes down to it, are the easiest to fix :)
actually heard mine do this tonight... might just chop it off be easier in the long run :lol:
