Nick
S3 engine conversion
I had a quick search, but couldnt find a definative answer.
Will an Audi S3 1.8 5V engine fit and work in my G60. I already have a VR6 clutch, but the engine comes with a 6 speed gearbox. Would i need this, or will it work by bolting to my 5 speed box?
I dont imagine it will, but you i wont know unless i ask.
Cheers in advance.
Nick
It will fit in. You'll have to use the 6speed box I would have thought and get the appropriate driveshafts.
Also you'll obviously need the ECU, wiring loom, etc etc to do the full transplant.
The engine comes with ECU, clocks, inlet & exhaust manifolds, keys, pipework and loom all on the subframe.
Doesnt come with driveshafts, can you explain what id need? :oops:
Would i need to source S3 driveshafts? Or a custom jobbie?
I couldn't tell you that far -
Is that the same as the V5 from the golf? or is it 5V??
If so check out dougs car on http://www.coupehaus.co.uk - I was getting the engine mixed with that, but even so it should still go in with a little enginuity (like what I did there!????)
The Audi S3 engines are the same as the golfs (5Valves per cylinder). The turbos are bigger on the S3's to get them t the 225bhp...
I would have thought the drive shafts would be different, but i could be wrong...
You have PM. 6spd box a PITA to fit and very heavy because of the transfer box bolted to it which you wont need being only FWD. It will also need custom mounts and driveshafts. Your g60 box will bolt straight to the 1.8t block which is the much easier option.
  gaz the geezer said:
............. looks like your not quite ready to let the corrado go yet Shaggsy, 8)
Cant afford this :(
:p @bank manager! :lol:
But no, no im not gaz.
