mrbeige 0 Posted May 16, 2007 Supercharged Junkie said: Am gutted really hoped to get mine fitted this week, but of course i book the first week in six weeks it rains all the time :-( I WILL get around to fitting mine soon No need! :( Typical english weather I guess :( Quote Share this post Link to post Share on other sites
mrbeige 0 Posted May 16, 2007 Getting hold of some Mk1 and 2 Golf clusters to trial fit a kit by the end of the month, but should work a treat :D Quote Share this post Link to post Share on other sites
j16jrf 0 Posted May 19, 2007 are these still available? Quote Share this post Link to post Share on other sites
smee 0 Posted May 20, 2007 Yes, I got one this week, the build quality is great, haven't fitted it yet but shouldn't be any trouble. Quote Share this post Link to post Share on other sites
j16jrf 0 Posted May 20, 2007 nice one can you pm me details mr beige please i will deffo take one off you Quote Share this post Link to post Share on other sites
flusted 0 Posted May 21, 2007 Just convinced my mate on the island to have 1 (didnt take alot!) just need payment details and hopefully you will be able to do the other bit i was after and post it all together? Cheers Quote Share this post Link to post Share on other sites
mrbeige 0 Posted May 30, 2007 Right, we may have a further feature for the shift light. It may well be possible to introduce a soft and hard rev limit to the system. We already have the provision for a high current driver that was originally there to run a shift-lamp, but with a bit of investigation we should be able to add some further software to the system to pull the coil down to earth and hey presto instant rev limit. I think a soft limit that toggles the output with a hard limit the switches it to ground should work ok. The question is how much interest is there? Price wise we're thinking; £70 for the shift light and rev limiter £85 for the shift light fitted and rev limiter (single wire that goes to the coil) What do you reckon? Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted May 30, 2007 Any-one know when the Stock ECu's soft limiter point is? Will this work and over-ride the factory limiter? All questions to think about.. ;) Quote Share this post Link to post Share on other sites
mrbeige 0 Posted May 30, 2007 That's a good point! I think you can get the limiter values through the MFA by following a given proceedure, but I'm not sure if there is any means to change or remove them. In which case the JSB system might only work if the limiting was required further down the rev range. :? Quote Share this post Link to post Share on other sites
flusted 0 Posted June 2, 2007 Thats a great idea, how did you come up with that? :lol: Just recieved my omex rev limiter and custom beige shift light, workmanship and build quality is amazing. The reason i went with rev limiter is with a 65mm pulley, you cant rev past 6k without harming the charger,and i think the g's limit is 7k?. The omex allows you to set the rev limit within 100rpm and also adjust the shift light as much as 2000rpm below the limit. Thanks for your help again Mr Beige il be fitting it tommorrow 8) Quote Share this post Link to post Share on other sites
mrbeige 0 Posted June 3, 2007 No problem Adie! The Omex just give me the idea, and it seems pretty simple to implement. Just wasn't sure of the application really. Quote Share this post Link to post Share on other sites
flusted 0 Posted June 3, 2007 well id strongly reccomend to anyone with a 65mm pulley on a G60 Quote Share this post Link to post Share on other sites
Petros 0 Posted June 5, 2007 mrbeige said: Right, we may have a further feature for the shift light. It may well be possible to introduce a soft and hard rev limit to the system. We already have the provision for a high current driver that was originally there to run a shift-lamp, but with a bit of investigation we should be able to add some further software to the system to pull the coil down to earth and hey presto instant rev limit. I think a soft limit that toggles the output with a hard limit the switches it to ground should work ok. The question is how much interest is there? Price wise we're thinking; £70 for the shift light and rev limiter £85 for the shift light fitted and rev limiter (single wire that goes to the coil) What do you reckon? I know this might be taking things a little too far... but it would be ideal if the soft limiter could be linked to the oil temperature, so you can't exceed 3krpms until your engine is safely warmed. I'd deffo buy one of those! That said, I'll probably buy one of the standard shift lights anyway, just as soon as I've got a few other repairs out of the way. Quote Share this post Link to post Share on other sites
mrbeige 0 Posted June 5, 2007 Petros said: I know this might be taking things a little too far... but it would be ideal if the soft limiter could be linked to the oil temperature, so you can't exceed 3krpms until your engine is safely warmed. I'd deffo buy one of those! That said, I'll probably buy one of the standard shift lights anyway, just as soon as I've got a few other repairs out of the way. I did actually consider this, but wasn't sure if it was feasible, as the temp senders are necessarily the same across all models, and the rpm inout is based on the pulse coming into the clocks, which is again different between the 4 and 6 cylinder models. I'll have a look into that though.... Quote Share this post Link to post Share on other sites
mrbeige 0 Posted June 25, 2007 Right, we've got three left of the current batch guys. Not sure if we are going to be doing more, it depends on how much more interest we can get... :? Quote Share this post Link to post Share on other sites
The_Dude 0 Posted June 25, 2007 I'll have one please, even though I don't have a Rado atm. Hopefully it will inspire me to be a bit less picky and just buy a another goddam car! :) Send me a pm or something about payment, I have paypal. Quote Share this post Link to post Share on other sites
mrbeige 0 Posted June 26, 2007 Corradude said: I'll have one please, even though I don't have a Rado atm. Hopefully it will inspire me to be a bit less picky and just buy a another goddam car! :) Send me a pm or something about payment, I have paypal. PM sent dude! Quote Share this post Link to post Share on other sites
The_Dude 0 Posted June 26, 2007 mrbeige said: PM sent dude! Payment sent, pm sent, heaven sent. :) Also, as you're pinging about this idea of a rev limiter, will it be available as an add on to your existing setup, or will you combine the two just for new customers? Or is it separate all together? Quote Share this post Link to post Share on other sites
mrbeige 0 Posted June 26, 2007 Ok guys, just TWO left. Lead time on next batch of boards is 6-8 weeks!! Quote Share this post Link to post Share on other sites
The_Dude 0 Posted July 4, 2007 Got mine yesterday, nice one Stu, looks like a quality piece of kit and the instructions look really clear too. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 4, 2007 i still want one, but atm have other things i need to spend the money on :( Quote Share this post Link to post Share on other sites
mrbeige 0 Posted July 4, 2007 Corradude said: Got mine yesterday, nice one Stu, looks like a quality piece of kit and the instructions look really clear too. No probs matey, cheer! Well, only one left now, before a month wait for the next batch! Quote Share this post Link to post Share on other sites
