LowG
16v temp sensor wire
can someone with a valver 1.8 or 2L have a look or if they know of top of their head the wire colour for the coolant temp sensor that send signal to cluster, it goes on the side of the head, if someone can snap a pic of their valver side of head with all the sensors and wire colour would be of great help.
thanks guys
  bcstudent said:
The 1.8 and 2.0 sensor arrangements are different aren't they?! Which one do you want specifically?
I was after the 1.8, the bentley manual dosent seem to have any info on 16v only G60 and VR6 :roll:
Like Crasher says...it's the yellow/red wire. If you still need a picture I'll try and sort one out. Someone may beat me to it though (hopefully :))
yep right wire guys, its was butchered so bad due to heat there wasnt any colour left to it, the spade conector was missing too. Now works fine, cheers fellas 8)
