skid
Door latch pins
Has anybody removed/fitted the latch Receiver pins on the A pillar.
I bought a new set as the nylon bush had got knackered(only cost £4.50 from VW).
I started to remove the first one but noticed the the nut behind the pillar is not fixed.
Does anyone know if this is held in or will just drop when i remove the pin fully?
:roll:
Yep, just mark the position of them if they are set up right, new ones are a different size to do up that the old ones - you need 14 and 15mm spanners
