Gee60 0 Posted September 24, 2003 So...if I take ISV off... anf blow inside the "thing" Should it be absolutely tight if ok ...no air leak trough it ? :shock: gee60 Quote Share this post Link to post Share on other sites
Gee60 0 Posted September 29, 2003 Every one talking about leaking ISV but noone can answer my simple question :?: :( Quote Share this post Link to post Share on other sites
dan 0 Posted September 29, 2003 What is the problem with your car? I think the ISV is too big to blow through! You just need to take it off the car & soak it overnight in some carburetor fluid. Quote Share this post Link to post Share on other sites
Gee60 0 Posted September 29, 2003 ...I think the ISV is too big to blow through... what u mean ? :shock: Quote Share this post Link to post Share on other sites
G60Jet 1 Posted September 29, 2003 Gee60, if it helps the Two i've got you can blow through when they are off the car, but not that much. I still to this day dont know if that is correct but hey, i've got a check valve now so im sorted. Quote Share this post Link to post Share on other sites
Gee60 0 Posted September 30, 2003 I have too the check valve assembled... but my question was actually theoretic.. Would it be so easy to find faulty ISV ? My ISV let air trough both way like an empty tube if I blow into ? :shock: Quote Share this post Link to post Share on other sites
Gee60 0 Posted September 30, 2003 and I have had idle problems (rough, hunting, stalling) for years... Quote Share this post Link to post Share on other sites
B5UBA 0 Posted October 14, 2003 if u dont mind me asking whats the isv Quote Share this post Link to post Share on other sites
big_mac 0 Posted October 14, 2003 ISV Idle Stabilisation Valve Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted October 14, 2003 No ISVs are not gas tight. The stepper motor inside controls the valve to alter the air flow characteristics ergo 'stabilising' the idle. Kev Quote Share this post Link to post Share on other sites
Gaz154 0 Posted January 12, 2004 where is the isv and what does it look like Quote Share this post Link to post Share on other sites
