covincharger 0 Posted July 10, 2006 has anyone know what sort of wiring is needed for this conversion.the engine in my covin is 1800cc 8v dignifant. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted July 10, 2006 The digifart is the later 90spec onwards loom and fuse box the donar car you will use will be plug and play. Quote Share this post Link to post Share on other sites
covincharger 0 Posted July 10, 2006 so what plugs in where ? so i can keep my fuse box and just plug in ecu?anything else,cant be that easy Quote Share this post Link to post Share on other sites
flusted 0 Posted July 11, 2006 The digifart is the later 90spec onwards loom and fuse box the donar car you will use will be plug and play. Only 90spec onwards digi was central electric. So if its got an 88/89 fusebox then it wont be plug n play. If it is central electric then the engine loom is only approx 3 plugs Quote Share this post Link to post Share on other sites
