G60 Bob 0 Posted July 11, 2006 There are several posts on this but none has an answer. Basically the MFA oil temp rises by 4 degrees when i switch the sidelights on and a further 4 degrees when the main beam is switched on and posts found during searches indicate its caused by a poor earth - it seems to be a common problem. However none of the previous posts have an answer as to which earth was causing this or indeed anyone who has actually solved the problem - any suggestions good corrado people? Quote Share this post Link to post Share on other sites
Crasher 4 Posted July 11, 2006 Almost incurable, my 83 G1 does it; my 88 and 89 G2's do it etc etc Quote Share this post Link to post Share on other sites
Henny 0 Posted July 12, 2006 change the main earth strap from the battery... it's the one with the battery clamp attached to it which then goes to the chassis and on to the gearbox mount. That'll normally sort it out... ;) (it has on all 3 of the corrados I've owned...) Quote Share this post Link to post Share on other sites
