RADO.001 0 Posted July 16, 2006 the fan on my heater only seems to work on number 1, any idea why 2,3,4 dont work? i used the search but only found threads on heaters/fan not working at all!? Quote Share this post Link to post Share on other sites
Bojmobile 0 Posted July 16, 2006 Mine's the same - it works on 1 and 4 - think it's a fairly common fault. You can find new fan parts quite cheap on Ebay that should sort it. I'm sure this is covered somewhere on the forum though. Nice looking C by the way! Quote Share this post Link to post Share on other sites
RADO.001 0 Posted July 16, 2006 dont surpose you know what parts i should be after do you? oh and thanks for comment on my C, yours is pretty tidy to tho Bojmobile, Quote Share this post Link to post Share on other sites
Bojmobile 0 Posted July 17, 2006 Think it's this part mate:- http://url.the-corrado.net/5f4876 and cheers for your comment! :thumbleft: Quote Share this post Link to post Share on other sites
RADO.001 0 Posted July 17, 2006 i thought it would have been a relay or something, because it dose work (if only on 1) so the motor is going!? but ill give this a go and see what happens. thanks for the link and all mate. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 17, 2006 I'd check the switch contacts first... Quote Share this post Link to post Share on other sites
Bojmobile 0 Posted July 17, 2006 I'd check the switch contacts first... Is that a common fault Supe? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 17, 2006 Yeah i think so - copper conatcts corrode, get dirty and also bend with wear so it may only be making contact at stage 1... Quote Share this post Link to post Share on other sites
RADO.001 0 Posted July 17, 2006 nice one Supercharged will check that out first then :thumbleft: Quote Share this post Link to post Share on other sites
Steve16v 0 Posted July 19, 2006 The usual problem is that it only works on 4...... this is due to a blown thermal fuse..... if it is only working on 1 I would first check the contacts at the switch, make sure that the socket is correctly pushed into the plug on the blower unit in the passenger side dash and if that hasn't sorted it do a continuity check on each of the wires coming from the switch to the fan Quote Share this post Link to post Share on other sites
jazzdevil 0 Posted July 19, 2006 Yeah i think so - copper conatcts corrode, get dirty and also bend with wear so it may only be making contact at stage 1... cool, just sorting a similar problem on mine [except i have the more common only-works-on-4 fault]... stupid question tho - how does the facer plate come off of the heater control knobs, i started prising it a moment ago and cracked it???? :? Quote Share this post Link to post Share on other sites
benkenobi57 0 Posted July 19, 2006 this is due to a blown thermal fuse that is the problem with mine steve only works on 4, is that fuse easy to get and replace?? Quote Share this post Link to post Share on other sites
Bojmobile 0 Posted July 19, 2006 Mine works on 1 and 4 - any ideas? Quote Share this post Link to post Share on other sites
benkenobi57 0 Posted July 19, 2006 afraid i dont Bojmobile its like the blind leading the blind here :lol: Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted July 19, 2006 Hi, See here I used this how to and mine works perfectley now..Not that it does anygood in this weather...Oh the days of Saab aircon :lol: Quote Share this post Link to post Share on other sites
myfirststorm 0 Posted July 22, 2006 thanks for the link. another job great :lol: Quote Share this post Link to post Share on other sites
big_chris1981 0 Posted July 29, 2006 mines stopped working on any setting.....any ideas as to what to change first? argh,. Quote Share this post Link to post Share on other sites
jazzdevil 0 Posted July 30, 2006 finally got to soldering in the new thermal fuse yesterday morning... didn't make a blind bit o' difference :x so off to Euro Car Parts i toddled and bought a new resistor pack for 20 notes... only thing is that the one i've been sold is only for a 4-pin power feed connection - missing the centre pin altogether... then it rained and i had to drive home with no de-misters :bad-words: one is not amused!!!!!!!!!!!!!! Quote Share this post Link to post Share on other sites
west-sidereason 0 Posted August 9, 2006 this anoying problem happend to me (91 Hreg), i'm not sure how it could be connected, but it magicly fixed itself when i put in a new battery. Quote Share this post Link to post Share on other sites
Baz2004 0 Posted September 12, 2009 mines stopped working on any setting.....any ideas as to what to change first? argh,. Ive the same problem in my early 16V, its been sitting up for 8 months now so im thinking the low battery could be a factor. I might pick up a fan motor and see if replacing it makes any difference. Quote Share this post Link to post Share on other sites
dragon green 6 Posted September 13, 2009 Yeah i think so - copper conatcts corrode, get dirty and also bend with wear so it may only be making contact at stage 1... cool, just sorting a similar problem on mine [except i have the more common only-works-on-4 fault]... stupid question tho - how does the facer plate come off of the heater control knobs, i started prising it a moment ago and cracked it???? :? they prise from the drivers side-gently fascias still available ffrom the stealers £34 Quote Share this post Link to post Share on other sites
