contender
Vag-Com
Hi
Does anyone know of a VAG-Com facility near Reigate. I have the ABS light on permanently. Hopefully the VAG-Com will give me an indication of what part to replace. The car is a VR6 '93 with the older style 2 pin connector. Look forward to hearing from someone.
I'm in the same boat, my mate works at VW so he's plugging it in tomorrow to see what the problem is.
  contender said:
Thanks for replying. Phrim? is that an author. I have done a search and that does not come up with anyone.
read pls ;)
PHIRM
webby
Checked all the plugs myself and the off side rear had no reading, took the wheel off and cleaned up the sensor it then showed a reading. Took it to my mate plugged it in and it came up with faulty off side rear and near side front sensors. Reset the system and the rear disappeared but the front was still showing.
He said the sensor is the same as a mk4 golf, said it would normally cost £154 but could do it for £105. Think I will source a sensor change it and get him to reset the vag com.
