lottysvdub
idle question
just a quick one guys my rado doesnt like to idle some times it can be hot or cold but when its playing up its a bitch , now recently ive had the throttle body off and given it a good clean and the same with the mass air flow meter , all seems ok what i want to know is when the engine is running its idling around 850 rpm if i pull the plug of the isv the idle increases to 1000 rpm , now when i plug it back in the idle stays at 1000rpm surely it should drop back to around 850 rpm , it only does this if i turn the engine off and then restart it , is this right ? and does anyone know the correct way to set up the base idle for a 1992 2ltr 16v , ive done a search and there seems to be a few different ways and now im really confused :scratch: :? :? :D
