vwdeviant
Boot loock replacement
Have finally got the new barrel/lock mech (Ok its sat in the sorting office awaiting redelivery, DON'T get me started about posties who won't ring doorbells!)
Just a quick question, how easy is it to change just the barrel so I can use my origninal key?
Ah nope it's a drift (rolled tube of metal)! Looks a real weak link.
Mind you when I had both locks side by side it was a shock just how much of the old mech had exploded! There was only 1/4 of it left in place. just have to see if I can get a copy of the original key until I can get to somewhere I can sort a drift out.
really easy no get apart. i used a nail to knock the pin out a little then used small vice grips to pull it the rest of the way. if i remember correctly theres a small spring flies out from somewhere when u seperate the barrel from the mechanism so do it slowly
