a98pmalcolm
cable through bulkhead
Depends what for I think, if it's for ICE there's a gromit that appears in the passenger footwell, behind the carpet. Otherwise there are more that pop out behind the dash.
Sorry if this sounds completely unhelpful, but go and have a look! :)
Moving to Exterior seeing as though this isn't about your engine.
Will take some pics tonight and post them on here of where mine went through. Its not that bad but you need to get most of the plastic trim out of the passenger footwell and then it is behind the carpet. I recommend that you run at least 4 guage cable through as then you can have about 120 amps of power through and I know my alternator pushes 90 amps so that gives a bit of spare!!
