cmoth 0 Posted September 6, 2006 Can someone please tell me where the 7th lead goes that comes with a new set of ignition leads, I cannot find the existing lead at all? Do I need to undo anything to reveal it? Thanks Col Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 6, 2006 Hello, the 7th lead will be the king lead that goes between the dizzy cap and coil... As you can't find where it goes I assume you have a 93 onwards VR6 with a coilpack (a block of plastic with the 6 connections) so you don't need it... Basically you've been sold the wrong set of leads... Quote Share this post Link to post Share on other sites
cmoth 0 Posted September 6, 2006 That answers that then , thanks! Are you saying the other 6 leads are not right then, as they seem ok and car appears to be driving well with them? Its a 94 M, so definately coilpack. Col Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 6, 2006 Yeah - it will be fine, I can't remember which leads are meant to be longer but as long as they're not stretched they'll be fine. Quote Share this post Link to post Share on other sites
cmoth 0 Posted September 6, 2006 thats cool. They dont have numbers on them for the cylinders, I just made sure that I did one at a time and measured each lead against the new one. Im using the Beru ones which Im led to believe are what VW use anyway. Im hoping my car will be cured now as cylinder 5 did not appear to be fitted properly as practically came off in my hands, which I hope was the cause of the car going into limp mode ( again!) Col Quote Share this post Link to post Share on other sites
