Ad2408
16v has forgotten how to idle
Hi
Hope someone can help, the girlfriends 1989 valver has suddenly forgotten to how to idle.
Wouldn't start first off (had to use a little bit of gas) then ran but idle is really low (around the 500 rpm mark)
As you can imagine the engine is bucking all over the place at that low RPM!
We went on a decent journey yesterday (around 50 miles) and it was flawless, started on the button each time. I actually commented on it! (Maybe i've jinxed it :oops: )
Any ideas whats caused it? And more importantly how to fix it?
Thanks in advance
Adam
Hi m8,
On the right hand side of the cylinder head there are 3 (iirc) senders with single spade terminals.
Just swap them around,and see if the problem goes away.
It dosn't matter which way they go as they are all the same part number.
(in fact the above is only worth trying if it wont idle at all)
If that shows no impovement it sounds like the isv (idle stabilisation valve) has stopped working.Its a cylinder shaped thing that should be buzzing just with the ignition on.
Neil. :)
my car stopped idling on saturday, it just kept cutting out when i took my foot off the accelerator pedal. so, i've just cleaned the 3 senders with single spade terminals on the right of the engine as suggested by Riley, and it worked 100%. so thanks mate you've indirectly saved me a lot of stress.
No probs m8,glad its sorted 8)
The isv can be cleaned with carb cleaner (available at halfords etc) or petrol.
Neil.
