kasman21 0 Posted October 1, 2006 Hey Guys my sunroof is is not sitting right, it is higher on one side than the other, anone know how to adjust it so that it will sit straight??? cheers guys Zak Quote Share this post Link to post Share on other sites
M15 VW 0 Posted October 1, 2006 4 torx head screws, two on each side in a slotted groove. adjust it from there. Quote Share this post Link to post Share on other sites
andy 0 Posted October 1, 2006 Normally you will have to slide the interior panel back, (basically get a good grip on it and heave it back, then you can get at the 4 torx screws that are used to hold/allign the exterior panel. Adjust as necessary (assuming that it is just panel adjustment that is required in your case) and then slide the interior panel forward into place again. Quote Share this post Link to post Share on other sites
