Ronan
G60 Rod Size
Can anyone tell me if this size rod will fit the G60 Corrado lump (Engine code PG)
Length: 144mm
Pin Size: 20mm
Journal size: 51mm
Would really help as I am struggling to find forged rods off the shelf for a decent price....
Which pistons/crank are you using ? the would help to determin wether or not those rods are any good to you
Standard crank, and unsure of pistons at the moment, will be going for some kind of forged items but not sure which brand yet.
read in the past the 144 rods are better as the std g60 rods at 136 or 139 (?) spin the shells at high rpm. however someone like darren will correct me if i am wrong. as for piston choices - there are a few easy sources - gwerks sell them and may have stock. otherwise the likes of je dircet from the states will make pistons to suit the rods. they basically move the pin up
As I said on Dubforce, if you are going for custom pistons, go for the 144's
Although the stock rods can take a lot of abuse eg T3 S60 and 1,5 no problem
