trundlemouse 0 Posted November 2, 2006 [color=#0000FF] :) Hello I have recently aquired a 1995 2.0 16v. I have a pretty good idea about the faults on the car. When I collected the car the passenger exterior door handle failed to open, I have seen repair kits on ebay ( In Germany and in the states) can anyone tell me if they work and if not what is the best route to take. Also the heater switch only works on postion 4 and the old owner has supplied the complete cluster temp, direction and switch. Does the whole unit have to be replaced. Any help gratefully received. Quote Share this post Link to post Share on other sites
Walesy 0 Posted November 2, 2006 Hello, good evening, and welcome :) There's a very nice chap on this very forum that produces and sells door handle repair kits that many members have used, it's a common fault ,Click here for the relevent thread. The heater problem is another common fault i'm afraid. Click here for a possible easy fix. You may need to swap the whole thing if that doesn't work, which isn't a problem if the seller has supplied you with one :) ( they are a sought after item and therfore they're expensive and difficult to find! ) It's allways worth using the search feature, you'll find most problems you come across have been discussed a few times before Hope that helps. Quote Share this post Link to post Share on other sites
trundlemouse 0 Posted November 2, 2006 Many thanks for your help Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 2, 2006 Welcome to the forum! This is more likely to be the blower fault... http://website.lineone.net/~quigger/heater.htm Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 2, 2006 Its daves16v that does the kits isnt it? They work a treat trundlemouse, and very little work to get them fitted. They go on ebay for around £30 + postage. I think daves16v does them a bit cheaper. Welcome to the forum mate! Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted November 2, 2006 It is daves16v that does them, try pm'ing him for a price on them etc Quote Share this post Link to post Share on other sites
