TREVR6 0 Posted November 4, 2006 Just hooked my vag-com up and it came up with two faults, just wondered if someone can shed a little light on the job :?: Fault 1; o2 sensor adaptation limit surpassed (intermittent) What does this mean? Changed o2 sensor recently cos it was showing o2 sensor no signal (intermittent) reset ecu and performed basic settings after it was fitted. Fault 2; Maf intermittent short to ground, would unplugging maf to see if car still ran (it didn't) bring this fault up or should I bite the bullet and buy a new maf. Car runs OK most of the time just with the occasional VR standard erratic idle and stalling at junctions. Both faults cleared and didn't come back, although I haven't been for a good drive to see if they reappear yet as I have to spend an evening with Stella and her 7 sisters! :drinking: :gag: Any help much appreciated, cheers chaps. Quote Share this post Link to post Share on other sites
Crasher 3 Posted November 4, 2006 Unplugging the MAF would cause that fault if the ignition was one. Can you post the fault code number for the lambda error? Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted November 4, 2006 if they clear and don't come back , don't worry about them. only worry about stuff that's stays there, or keeps coming back. Quote Share this post Link to post Share on other sites
TREVR6 0 Posted November 5, 2006 Can you post the fault code number for the lambda error? Na forgot to copy the faults to my note pad :oops: I'll see if it comes back and if so post the fault code up, Cheers. Quote Share this post Link to post Share on other sites
