Stakis
How to change hydro valve lifters of g60 to solid ones?
The main problem is that the mechanical lifter valves are longer but the lack of a cam bearing on journal 4 could be a long term issue if the engine was being used at very high RPM. Why do you want to do this?
I hheard and got FORD diesel lifters..they are the same diameter, but they are a little bit different. I tried to measure, the difference is about 5.5mm, but i think i can't get to purchase such a big regulating plates?
i have a problem.the car don't go over 4000rpm.. it blurbbssss ant thats all.. So i believe that the lifters here is the problem. because the don't open valves, when the exhaust gases are smaller, the turbo stops to spool, but the computer spray a lot of fuel..and... so i want to change them to mehcanical ones.
