timmaaah 0 Posted November 23, 2006 Right - I was wiring in a power supply for me gps unit. I used the switched live from the ignition that goes in the back of the stereo (brown with red trace iirc). At one point I stupidly managed to short this out to earth :roll: . It now has no power going to it. I've found the cable coming out from the ignition switch - am I correct in assuming that the switch has probably melted (I've got continuity from the multi plug in the ignition switch to the stereo end meaning the cable its self if ok) and I'm gonna have to replace it, or is there a fuse somewhere that may have blown (none blown in the fusebox) Please help as I've now got no tunes :cry: Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted November 24, 2006 1 Headlight, low beam, left 10 2 Headlight, low beam, right 10 3 Instrument panel lights, license plate lights 10 4 Rear window wiper 15 5 Wiper/washer, front 15 6 Fresh air fan 20 7 Tail lights, side marker light, right 10 8 Tail lights, side marker light, left 10 9 Rear window defogger 20 10 Foglights 15 11 Headlight, high beam, left 10 12 Headlight, high beam, right 10 13 Horn, radiator fan run-on 10 14 Back-up lights, washer jet heaters 10 15 Electronic ignition, idle stabilizer, deceleration fuel shut off 10 16 Dash warning lights, glove box light, cassette storage light, rear spoiler adjustment control unit 15 17 Emergency flasher switch, turn signals 10 18 Fuel pump 20 19 Radiator coolant fan, A/C 30 20 Brake lights 10 21 Interior lights, cigarette lighter, digital clock, rear spoiler adjustment 15 22 Radio 10 fuses , why not just take an ignition live from somewhere else and ignore it :-) Quote Share this post Link to post Share on other sites
