vwdeviant
The Forced Induction 16V Thread
The PG pistons have the combustion chamber in the pistons (dome - refered to as "depth" in your data?). The 16V and S2 has it in the heads, so there's less dome (depth?)
S2 rods/pistons + engine block with the right bore (stock PG f.ex.) and KR/PL/ABF head is iirc a very successful combo.
WoW! Thanks WORMY! Quite quick usefull answer!
Maybe you can answer me to another questions (maybe plus some photos):
2. I don't find what kind of distributor I can/have to use because I need a Hall sensor not a Delco (for my PG Digifant1).
3. I don't find what spacers I have to use for Water pump and Steering pump pulleys, or what I need to shave from other pulleys.
4. Something about 16V Secondary shaft and gears?
Theese are some of a kind of bolt-on stuffs? Or there are some mods?
---------- Post added at 7:48 PM ---------- Previous post was at 7:46 PM ----------
1. I don't find what kind of distributor I can/have to use because I need a Hall sensor not a Delco (for my PG Digifant1).
2. I don't find what spacers I have to use for Water pump and Steering pump pulleys, or what I need to shave from other pulleys.
3. Something about 16V Secondary shaft and gears?
No photos available at the moment, sorry.. But I'll try to answer.
I think I'd go for a 16V distributor that fits in the cylinder head - and block of the G60 one that fits in the block.
IIRC (I'm not 100% sure!) you also need a 16V intermediate shaft and 16v oil pump.
For the pulleys - the 16V timing pulleys are wider, so you need spacers - or replace the pulleys/pumps with 16v units. BBM sold the spacers separately before, but I can't find them on their site anymore.
By the time you are done, I think it'd be cheaper and easier to try to source a complete 1.8L KR engine (or PL, but they have lazy camshafts), and just replace the pistons/rods with S2 units - instead of trying to "modify" the PG block to fit the 16V head? Unless you have special reasons for using the PG though.. :-)
From my experience - most PG blocks have bores that are totally out of specc anyway - I've even had piston slap in one engine! They'd need a re-bore, so the S2 pistons won't fit.. :-\
Edited by wormy
Well, I must keep the PG for Auto Registration.
"you also need a 16V intermediate shaft and 16v oil pump." I believe the reason is the larger debit needed for the 16 valve head, isn't it? So, here comes another question: The KR head fits exactly on PG block? Because I do find somewhere on a site (I forgotten where) there are some modifications to be done on the oil channels between head and block: some channel must blocked and other channel must bigger rebored. Which one and what?
