JIMMI 0 Posted December 5, 2006 Hi dudes Ive got a VR6 here with a non functioning temperature gauge, it wont even move from the stop. Ive changed both the Yellow & Blue temp sensors with brand new VAG items today and it still wont register anything on the gauge. Im thinking its either a problem with the wiring or a fault in the clocks, so i need to earth the gauge out to see if i can get any sort of reading, which wires do i need to earth out on the yellow sensor to do this ??? Cheers Jimmi................... Quote Share this post Link to post Share on other sites
Crasher 4 Posted December 5, 2006 Brown/green pin 3 onto blue/white at pin 2. If you do this you can damage the fascia. Really you should put a 75Ω resistor across these pins to simulate approx 100°c. Quote Share this post Link to post Share on other sites
JIMMI 0 Posted December 6, 2006 Cheers for the reply mate is a 75 ohm resister easily available from the likes of maplins ??? also do the wires from the sensor go straight into the back of the clocks or do they go to the ecu ? i would like to do a continuity test on them. cheers. jimmi......... Quote Share this post Link to post Share on other sites
