jimmy p
Please help before its too late!!!!
When i start my car (vr6) sometimes the headunit comes on and sometimes it doesn't. :cry:
Theres no power getting to the headunit when this happens. If i wiggle the key in the ignition back and forth a little bit it comes on. Is this the start of my ignition switch going faulty?
Is it going to get worse and how much will it cost to fix? Is it easy to do aswell?
Thnks for helpin me, and i hope its not expensive :wink:
Ignition switch needs replacing, not expensive but an arse of a job to do as its a tiny screw in a very inconvenient place!
actually not sure if i mean ignition switch, its the push switch that's in the ignition barrel anyway that needs replacing
Yeah it's part of the ignition switch itself but it may be happening if the switch has been replaced but not screwed in and has slipped out the lock housing... take the lower cowling off to check.
