_leon_ 0 Posted December 13, 2006 Standard Corrado 4 stud wheel bolt sizes are: Thread - M12x1.5mm - fine pitch? Seat - Radius HEX - 17mm Thread length - 23.5mm The wheels I'm using now don't have the standard seats - instead they have 60 degree radius seats. After having a search online I can't find bolts with the correct thread length - best found yet is 26mm, see here: http://www.priracing.com/product.php?xProd=679 Can Corrado hubs (G60) take longer bolts? Not sure if the hub seats have exits or whether a longer bolt will fit the 'bottom' of the thread seat or not? Are the 26mm bolts above ok to use? Thanks for any help Quote Share this post Link to post Share on other sites
tom_rob_89 10 Posted June 26, 2015 Hay man did u ever find out if the 26mm one's fitted? Cheers Tom Quote Share this post Link to post Share on other sites
