alackofspeed2 0 Posted December 16, 2006 Hi, Myself and a friend are rebuilding a VR, and having now got the block back from the machine shop, the next stage is to fit the pistons. With the cylinders being at an angle to the block face, I'm imagining it's going to be a more difficult exercise than fitting would be with perpendicular bores. Does anyone know of recommended techniques? Any helpful suggestions would be really appreciated....... before we start snapping rings, and scoring bores :shock: :D Cheers, John. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 16, 2006 I used a standard spring compression tool and sliced it on a angle to the bores. Quote Share this post Link to post Share on other sites
alackofspeed2 0 Posted December 18, 2006 Cheers for the reply. What did you use to cut the ring compressor? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 18, 2006 used a plasma cutter. Grinder would be fine aswell...lol! Quote Share this post Link to post Share on other sites
