corradovr6sc 0 Posted October 13, 2003 I fitted a mocal 13 row cooler to my vr about a month ago but it doesn't seem to be working properly. The oil temps still rose to 140 degrees on the track. I thought the thermostat on the sandwich plate may have been faulty so I swapped it for a new s-plate yet the temps still seem to rise and the car still runs at 100+ degrees. Does anybody know any likely causes of the problem? Is it possible to have an air lock which prevents the oil circulating? What temps should I be seeing if the oil cooler is functioning properly? :( Thanks Ben Quote Share this post Link to post Share on other sites
G60 0 Posted October 14, 2003 could be another problem altogether... did the oil cooler help at all?? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted October 14, 2003 Try blocking the cooler and see if it makes a difference. If the engine doesn't run any hotter then it's not doing it's job. My mocal gives me readings of 94-98 with moderate driving and around 102-104 when pushing it. Prior to it's fitment I was getting 114 cruising at 80 mph! Check you have no kinks in the hoses and when the engine is running and oil above 80 degrees, feel the hoses and they should pulsate, indicating a flow. Where did you mount the cooler? It might not be getting enough air. Mine's in front of the radiator. Kev Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted October 14, 2003 I have mounted it directly behind the plastic grille (has the slots cut out), infront of the radiator. My hoses are straight. Should the cooler (radiator) get hot?-I have felt it and it always feels cold. I have taken a hose off to make sure oil is flowing into the cooler and that seems ok. :? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted October 14, 2003 Yep it should be hot, just like the water radiator. Did you check the other hose to see if that was wet with oil aswell? You might have a duff one with an internal blockage or something. Kev Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted October 14, 2003 I'll check both hoses. Is it possible to get an air lock in the hoses or cooler? . The only other thing I can think of is that the cooler was filled with oil then left for about a year before I fitted it. Could it have become sludged up? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 15, 2003 It sounds like the thermostat in the sandwich plate is not opening but you have already swapped it?? - maybe its the wrong part? Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted October 15, 2003 I swapped my original thermostatic sandwich plate for a new 90 degree item but I have yet to examine both hoses and check for blockages. Should you be able to blow through the cooler? Quote Share this post Link to post Share on other sites
h100vw 0 Posted October 15, 2003 corradovr6sc, I have a cooler fitted on my G60 Golf. It runs under 80degrees most of the time. On trackdays it can go up to 125 or so. The thing I see with mine is that the temps drop like a stone as soon as you get off the gas on to the warm up reg. I reckon yours is going ok. If you do plenty of trackdays, then maybe a bigger radiator would be a good idea. Gavin Quote Share this post Link to post Share on other sites
corradovr6sc 0 Posted October 15, 2003 Thanks for the replies. I cannot think what it can be. It is installed correctly. I'm going to have to do more testing and explore the possibilities. Quote Share this post Link to post Share on other sites
