allstaruk
Newbie - hello
Nice one cheers mate I will have a go at that on saturday, anythings better that listerning to my fried moaning about his car not working propperly.
I can't find any picture to show ya' but basically it lives to the right of the engine block, just above the distributor. It's a black cylinder about 2" in diameter (and about 6" long). It's held in place by a rubber loop. There's an electrical connection (plug) on the end facing the windscreen and there should be two pipes coming out of it... one directly opposite the plug, the other pointing down at 90 deg. to the first one. Simply unplug the connector, remove the two pipes (can take some doing!) and then slide out of the rubber loop (it's heavier than you think!)
thats the aux water pump ur describing
