j16jrf
washer jet removal
i am getting my bonnet smoothed and need to know if anyone has done this before?
If so where did you put your washer jets?
Thanks in advance
Jamie
how do you remove them from the bonnet? they unskrew? or clip in? cheers..
I thought they just pushed in, may be wrong though?
Ian.
i had a butchers the otherday, didnt want to damage anything but realy cant see how else they would come out, i shal try with abit of force, cheers
They are clipped in.
Lift the bonnet. Disconnect the washer fluid tube. Put your finger on the rear edge nearest the windscreen. Squeeze the whole edge forwards while also pushing upwards out the the bonnet. Each should pop through the bonnet to the top side. Disconnect the wire connector and pull the wire and connetor through the hole.
