C. Will Corrado G60 2
The Alloy Wheel Nightmare!!!!!!!!
I've gone for an 8" wheel instead as the work involved to make 9" fit would change the look of the arches which is something I don't want to do.
Having Coilovers is making it harder as well due to the spring hitting the wheel.
Cheers
fitting coilovers makes fitting a whole load easier ... look at one compared to a std rear shock /spring assy and look how thick a std set up it it would rub alot more...
ok i suppose it depends on how low you are running the car ... all i can say is that i have fitted and run for over a yr 9-16"s and they have never come anywahere near to touching my koni coilovers ...
the car is now producing exactlly 0 bhp as its off the road ...
the cut out is a feed for the front mounted intercooler...
