BigTartanJudge
Will FK Konigsports for a rado G60 FIT a rado VR6 ?
Ok,
I need to know if my FK Konigsports purchased for my G60 some time ago will ALSO FIT a rado VR6 in the same way. I know the spring rates are different usually for G60 / VR6 suspension model variants, but just need to know if the fit is the same.
Regards
The part no for the 16v/G60 coilovers is: FKKKVW57, the one for the VR6 is: FKKKVW58. You can assume that they would have the same part number if they were the same. Perhaps, as you mentioned it's just the spring rate that differs between the models?
