G60SC_Stoney 0 Posted February 16, 2007 as above, is it an easy swap to fit VR6 hubs onto a G60? really like the look of some 17" BBS RS and cant fit them due to being 5x120, and as the G60 is being pulled apart, wondered if VR6 hubs are a straight swap?? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 16, 2007 I think you just need VR6 outer CV's.... Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted February 16, 2007 as above, is it an easy swap to fit VR6 hubs onto a G60? really like the look of some 17" BBS RS and cant fit them due to being 5x120, and as the G60 is being pulled apart, wondered if VR6 hubs are a straight swap?? Why can't you fit 5x120 with adapters??? VR6 Hubs wont fit them either as are 5x100!!! Quote Share this post Link to post Share on other sites
G60SC_Stoney 0 Posted February 16, 2007 VR6 Hubs wont fit them either as are 5x100!!! cant get 4x100>5x120 adapters but you can get 5x100>5x120 adapters hence the need for VR6 hubs. Quote Share this post Link to post Share on other sites
flusted 0 Posted February 17, 2007 to fit the complete hub, you need wishbones, ball joints, and cv joints to go wide track which is 6mm wider. Quote Share this post Link to post Share on other sites
G60SC_Stoney 0 Posted February 17, 2007 and what about to do the rear? Quote Share this post Link to post Share on other sites
G60SC_Stoney 0 Posted February 17, 2007 and also are the hubs the same across the whole of the vr6 range ? i.e golf vr6 vento vr6 ? i know a mate who is breaking a vento, so can get some bits for nothing/not much. Quote Share this post Link to post Share on other sites
BigTartanJudge 0 Posted February 18, 2007 For rears you just need new rear discs, for fronts bit more involved but do-able and plenty donor cars breaking all the time for complete front 5-stud change. Quote Share this post Link to post Share on other sites
flusted 0 Posted February 18, 2007 and also are the hubs the same across the whole of the vr6 range ? i.e golf vr6 vento vr6 ? i know a mate who is breaking a vento, so can get some bits for nothing/not much. When i did the 5stud conversion, i used vento parts. Remembered you need to use the anti roll bar aswell Quote Share this post Link to post Share on other sites
G60SC_Stoney 0 Posted February 18, 2007 cheers guys, info much appreciated Quote Share this post Link to post Share on other sites
