mondy
G60 Toothed Belt Part Number
Hi,
Does anyone know the part number of the belt that is used on the toothed belt conversions? Mine decided to strip all the teeth off it today!
Thanks,
David.
You mean the accessory belt toothed drive conversion? If it stripped the teeth off of one of those, there is a problem.
Yeah the one that goes round the charger/alternater/waterpump etc
I seem to remember reading somewhere these conversions are prone to doing this but can't find the post now!
The belt you need is - 8m1600 /20mm. Check the idler hasn't gone out of alignment also. Available from stock if required.
