vwdeviant
Wire fishing....
Ok when changing the light switch on the driver's A pillar I managed to "lose" the wire... Tried needle nosed pilars but no sucess...
Any-one got any tips to fishing the little bugger out?
Help, I don't have an interior light which is annoying, but also the Clifford's not working either as it see the door open when I arm it!
....... get to it from behind?
It's not the solution to everything Dom .... :nono:
What's on the end of the wire, connector-wise? Can you see it at all through the hole? I'd try getting some wire and bending a nice tight hook into it and trying to catch it with that, but you've probably already tried that...
