VEEDUBBED
Con-rod shell bearings...
Right lads,
Are the shell bearings fitted to turbo diesel golfs.passats etc stronger than say,the bearings fitted to the g60 engines?.
Are there any differences?,are they made of stronger material? and do the shells have small oil holes like the 2.0 9A mill's versions.
thoughts pleeze.
TD lower rod bearings are Sputter coated like the G60 bearings although bizarrely VW no longer differentiate between G60 and 16v.
