CTWG60
you can't go from 4x100 to 5x112 simply using adaptors... at least, not safely, and anyone who is saying that you can will be supplying 2 piece adaptors that are a minimum of 40mm thick in total meaning that any wheels will have to have a mad offset to fit properly... :roll:
Your best bet is to convert the car to 5x100 and then use adaptors to change 5x100 to 5x112.... Dubwhizz has done this on his Golf G60 Oettinger.
Change the rear disks to VR6 ones (that's the rear 5x100 conversion done!) and then change the front hubs, bearings and a few other bits to convert that to 5x100. You'll then need a set of 4 5x100 to 5x112 convertors (make sure they're TUV approved!) which tend to be around 20 to 25mm thick meaning that you'll need a wheel with an offset to suit having a spacer that large behind them...
