Cnut
RCA leads
All the bits to my new ICE setup have now finally arrived.
I'm running a 4 channel amp to a set of components up front plus a couple of subs at the rear.
The amp wiring kit I purchased came with one set of RCA leads.
Will I need 2 sets of RCA leads? because my headunit has: front, rear and sub RCA outputs and the amp has: front, rear inputs + an aux output.
Cheers
Thanks, does the connection from the headunit to the amp go: sub to rear or rear to rear?!
If you understand what I mean!
The sub out should go to the two channels powering your subs. If you are only running front components the rear output from the head unit will not be used.
