dazzyvr6 0 Posted October 29, 2003 this is what happened when i was passing a load of lorries at around 70mph in the rain,the passenger side wipers just seemed to tottaly lose itself,not sure whats happend yet just hope the shaft hasnt sheered off,and hope the motor hasnt burnt out as it was stuck there for at least 10 miles till i could pull over :? :shock: Quote Share this post Link to post Share on other sites
Beetlebug_2001 0 Posted October 29, 2003 Has the bolt holding it on not just come lose so its not gripping when the motors turning, used to do it on my old beetle. Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted October 29, 2003 SHOULD BE OK MINE GOT STUCK FOR ABOUT 15 MINS ONCE ON THE MOTORWAY, BUT THAT WAS DUE TO A RAG GETTING CAUGHT UP IN THE MECH,, HEY WHAT SUSPENSION YOU RUNNING, YOUR CAR IS SITTING ABOUT HOW I WOULD LIKE MINE TO SIT AT,, :roll: Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted October 29, 2003 im hoping it is just the bolt thats come lose olly elworthy, im running spax coil overs,at around 60mm drop :D Quote Share this post Link to post Share on other sites
Nick_Micouris 0 Posted October 29, 2003 That EXACT same thing happened to me after GTI international... The bolt had come loose on the passenger arm and the arm was banging at full speed then it came off too far and mangled itself in the drivers side. Have now gone for the higly recommended Lupo mod. BUT even after done I noticed the wipers were banging. I checked the spline on the spindle - looked fine. Turns out that the spindle itself had become loose and needed tightening down as it was making the arm move further than intended. Have a look check the large hex bolt that holds the actual spindle down is secure. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted October 29, 2003 will do,cheers Nick_Micouris, Quote Share this post Link to post Share on other sites
matt buz 0 Posted October 29, 2003 i had that on my golf a loose nut in the end Quote Share this post Link to post Share on other sites
