Badger
Who would service my vr?
I have had my vr for nearly a week now and everything is smashing but i am now starting to think ahead. The service history that came with the car is all Volkswagen.
Now in an ideal world i would like to keep it that way but the expense would eventualy need me to sell a Kidney.
So can anyone recommend a good specialist in the west midlands or north west area thats up to the job?
I keep mine FVWSH'd by supplying the oil and getting VW to do an annual oil change,obviously dearer than a specialist but not too much.......for anything other than that I use a specialist/mechanic mate
Presume you're near Telford or similar. If I was unable to do the work my self, I know of a good cheap local garage that will fit bits that I buy. ie you can buy the proper Silver oil off GSF or VAG, then I'd buy a genuine VAG oil filter and air filter. And let your chosen garage replace those items and then check the usual suspects, brake pads etc, also noting plug status.
Maybe a once over by a VW specialist just to give you piece of mind on your first service. Then find a local that you trust IMO.
