peanut 0 Posted April 13, 2007 aloha, getting desperate now, trying to source a multi v belt for a z-engineering charger. The exact size needed is a 7DPK1710 mulit v belt. Theres a 5mm gap between the troughs. Can get away with a 6-rib or even an 8 or or 9 rib as i can take some ribs off. Anyone know of anybody that can make belts up to spec? Tried all the likely places like gates etc but no use Gav Quote Share this post Link to post Share on other sites
G60SC_Stoney 0 Posted April 13, 2007 go onto the VR6oc and ask a guy on there called SIMEY. he is a mate of a mate and is always buying belts for his zr2 charger, im sure he will know.... Quote Share this post Link to post Share on other sites
peanut 0 Posted April 13, 2007 ok cheers will have a look now Gav Quote Share this post Link to post Share on other sites
H8RRA 0 Posted April 13, 2007 i've been supplying belts for vortechs and should be able to get you a price on these no probs - give me a couple of hours Paul - Quote Share this post Link to post Share on other sites
peanut 0 Posted April 13, 2007 :mad: fingers crossed Quote Share this post Link to post Share on other sites
H8RRA 0 Posted April 13, 2007 double sided 1710's don't exist - theres only 1383's which suit the vortecs nicely and then 2000+ which are far too big - tried 5-9 rib as well single sided belts are available????? Quote Share this post Link to post Share on other sites
M15 VW 0 Posted April 13, 2007 well thats the one I have. Someone said they could get an 18?? today so they do exist under 2000 in a 7 ribbed. Found a 1750 in germany but they wanted £90 for it. The length is slightly variable. Does no one know of any place that makes belts up? Quote Share this post Link to post Share on other sites
Toad 0 Posted April 13, 2007 Try Blue Diamond in Chandlers Ford. They might be able to help you. Otherwise I'll ask around at the weekend. Quote Share this post Link to post Share on other sites
M15 VW 0 Posted April 13, 2007 thanks, I will do :) Quote Share this post Link to post Share on other sites
M15 VW 0 Posted April 21, 2007 Ive finally found a really close match to my belt! its a 7dpk 1686. SHould get it within a week so we shall see. This belt is actually used on z's so I reckon it should be ok Quote Share this post Link to post Share on other sites
M15 VW 0 Posted May 19, 2007 Yep it is the right one! Thank god for that! found somewhere that does the Z-engineering parts. :) Quote Share this post Link to post Share on other sites
