fla 9 Posted April 23, 2007 For sme reason the front bumper rattles as i drive over an uneven surface. OK, i say front bumper it could be something else that vibrates at the front right of the car. The bolts are in ok, and the sides are in the two carrier slots, although the drivers side does seem to have a little amount of "rattle" movement. Any ideas or suggestions? I hate rattles and squeeks in my car and this is just a further annoyance. Quote Share this post Link to post Share on other sites
fla 9 Posted April 26, 2007 Rattle is probably not the best word, its more of a rumble. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 26, 2007 Could be the plastic bits the sides slide into or the arch liner... But, I would also check the middle bolt holding the crossmember hasn't snapped (seen this before when work is done and old rusty bolts not replaced etc) If looking into the above make sure you jack the engine mount before you remove the bumper incase it drops! Quote Share this post Link to post Share on other sites
