Sandy
supercharger upgrades
Hello Folks,
Is it worth the money getting your charger upgraded above a stage 4 conversion ??? :roll:
This is what I've had done so far gives me around 210bhp/207lbs/ft torque so if I went higher than a stage 4 what figures would I be looking at ???
AMD CHIP & PULLEY PLUS STAGE 3 CONVERSION ON THE SUPERCHARGER
VIBRATECH FRONT ENGINE MOUNT
K&N PANEL FILTER
SUPER SPRINT CAT BYPASS PIPE
SCORPION STAINLESS STEEL EXHAUST
BIG VALVE HEAD
SUPER SPRINT MANIFOLD 4 TO 1
SCHRICK CAM
ADJUSTABLE FUEL PRESSURE REGULATOR (FUEL PRESSURE * 2)
I am using a 70mm pulley and I think I am loosing a wee bit of power due to my exhaust not enough back pressure I am told.
Perhaps you should go for a 68mm pulley. You wont lose power with a large bore exhaust, you may lose bottom end torque but unlike turbos the charger doesnt need back pressure to perform.
sorry dubcharged, but just wanted to pick you up on something, turbo chargers do not like back pressure at all.
the best exhaust on a turbo charged car is no exhaust since you want the largest pressure ratio accorss the impeller as possible in order to get it to spin as efficiently as possible.
The only time you would ever want back pressure is before the turbo has spooled up, at which point the engine is effectively normally aspirated.
On turbocharged engines, the torque gain realised by the turbo far exceeds that which comes from having high back pressure when offboost, so most of us choose to remove the back pressure just to bring the turbo in as soon as possible.
Hi,
Just got back from Jabbasport :lol: :lol:
Had R1 supercharger service
68mm Pulley & Chip
Port and Polished Head
Flowed inlet manifold
Piper 285 Cam
Head set
Koni Coilover kit (72mm drop) 8)
Already seems lots and lots better
Will know more in about 300 miles time when I can go over 4000revs :twisted:
With other minor bits and pieces nearly 3k
When I got home I installed my newly bought 2nd hand leather interior.
Nearly finished as a project will perhaps post photos soon.
(need to clean the beast first) :D
Did you win somethign ont he lottery :)
Or you been saving up for that lot for while?
Sounds great tho...bet it flies once its run in :p
Been saving for a while. Wanted to do all at once (saves on workshop time)
Also Chip would have to be changed with different specs on engine. Only one chip change instead of 2 or maybe 3.
Had car about 6 months now and was happy b4 :) now :D :D
