SIG60
17" Wheels
Hi, Will Porsche Boxster 17" Cup Alloys fit? The sizes are as follows:
Front wheels are 17" x 7" with an Offset of ET 55
They are running on 205/50/17 tyres
Rear wheels are 17" x 8.5 with an Offset of ET 50
These are running on 225/40/17 tyres
fit straight onto my G60?
The G60 is 4 stud bolt pattern so unless you get a hub adaptor type thing, I think they won't go straight on. Also, do you know what the PCD or the Porche wheels is?
well unless you have 5-stud hubs(which is a VR6 only fit) then the answer is no........even if you have the VR's 5-stud hubs on the porsche PCD is totally different to the VR's one
so looks like you can't unless you get some hub adapters etc
h&r do addators for 4 stud corrados, but the space the wheel out by 25mm
so you will be left with an offset of 30mm on the front, and 25mm on the back
the fronts will fit, if you change the tire to 205/40/17
the rear arches will need rolling right out and smoothing over
(if used with the h&r addaptors)
these wheels will fit perfect with the h&r adapters ... ps there is some on ebay.de at the moment for good money .
Thanks everyone!! I dont think I will bother but if anyone else is interested I found some with tyres for £400.
