Trakx 0 Posted May 4, 2007 does your dump valve expells air at idle?? (jusy a small brise) Quote Share this post Link to post Share on other sites
flusted 0 Posted May 4, 2007 should do i think Quote Share this post Link to post Share on other sites
eatthis 0 Posted May 4, 2007 why would it? i thought they didnt Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 4, 2007 Nope, they shouldn't dump air at idle. Your BOV spring is too soft. Or are you using a twin piston one? They work a bit differently.... Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted May 4, 2007 I've got a bailey piston jobbie fitted to my turboed valver and it's definatly open at idle,as soon as it gets a whif of positive boost it shuts,exellent piece of hardware. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 4, 2007 Yeah my Forge Twin piston did that aswell, but my 50mm TIAL stays shut until you back off the gas. Quote Share this post Link to post Share on other sites
flusted 0 Posted May 4, 2007 the vacuum on the top of it lifts the diaphragm doesnt it, then when it hits posiutive pressure, it shuts? Quote Share this post Link to post Share on other sites
RS VR6 0 Posted May 4, 2007 Are you talking blowoff valve or wastegate? They are two different parts, that do two different things. Quote Share this post Link to post Share on other sites
CrazyDave 0 Posted May 4, 2007 Mine is fully shut at idle. It's a Tial similar to Kev's but with a 12psi spring fitted I think? Quote Share this post Link to post Share on other sites
Trakx 0 Posted May 5, 2007 i'm refering to a blowout valve, not a wastegate. Quote Share this post Link to post Share on other sites
RS VR6 0 Posted May 5, 2007 A blowoff valve normally is open when the engine is under vaccum(idle/ partial throttle). It closes then the car is under boost. Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted May 5, 2007 baily do a twin piston jobbie for k-jet cars which is open at idle but shuts as soon as you come off idle. normal ones are shut till the negative boost is greater then the positive boost and then it vents to the atmosphire Quote Share this post Link to post Share on other sites
