16vrixter
1990 1.8 16v Starting problem, no spark and no fuel
It wasnt the ignition switch:
Ok I got Donaldsons in Clydebank (A garage recommended on here) to pick up the car about 2 weeks ago. They had an auto electrician check it out and he found that ECU was burnt out, most likely caused by the dodgy immobiliser wiring that he also found. Auto electrician is going to see if he can overhaul the ECU and might be back on the road within a week :D
Really glad that the end is in sight.........
make sure whatever you're using to operate the new ignition switch is pressing the button in on the inside
hey saysomestuff I have just noticed you've been editting the photos......thanks! :D :D
