steveo29 0 Posted November 1, 2003 my 16v kr seems to rev hard on cold starts sinse it got colder ...it will rev to 2500 ish on every cold start,it then settles to 1100 after a few seconds..a few people said its normal but it seems too much?? what does yours rev to on a cold start? ive checked isv,temp senders,flap height in airbox,thottle switch,idle set up cheers for any help Quote Share this post Link to post Share on other sites
joebrent 0 Posted November 1, 2003 if you mean idle, myne starts at about 1500-1800 then sits at about 1000! hope that helps Quote Share this post Link to post Share on other sites
steveo29 0 Posted November 1, 2003 yeah thats what i mean...so judging by you mine revs way too hard anyone know how to alter it? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 1, 2003 When it's idling at 2500rpm, tap the idle valve with a hammer and see what happens then. If it drops to 1100 straight away, try cleaning the valve out with some carb cleaner and then a little WD40 to keep the valve lubricated. A KR should idle at 1100 when cold and then 950 when hot. Your base CO might be out too. KRs run best at 2.0% CO. Kev Quote Share this post Link to post Share on other sites
steveo29 0 Posted November 1, 2003 no..its no a faulty isv...it goes to 2500 on start up then gently settles to 1100 ish wouldnt the c/o need to be miles out to cause that?..anyway it idles at 900 with the isv disconected Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 1, 2003 OK, around the thermotime switch are 3 temp senders. One of them (blue/white wire from memory) controls the idle speed. Check the wiring here. The idle should be 1000rpm with the isv disconnected. Kev Quote Share this post Link to post Share on other sites
steveo29 0 Posted November 1, 2003 checked...all good ,sensors are all the same ohms...cheers anyway :D Quote Share this post Link to post Share on other sites
Adam Darby 0 Posted November 3, 2003 just out of intereast were abouts it the ISV is it on the top of the throttle body and its just has a brass type screw valve? Quote Share this post Link to post Share on other sites
steveo29 0 Posted November 3, 2003 standing in front the car..its at the right end of the rocker cover on a 16v..small clyindrical(sp) thing Quote Share this post Link to post Share on other sites
